84_Chevy_K10
Banned
crazy_swede_73 said:Anti wrap bar without shackle, works great!!
Wheel travel from your leaf springs was apparently optional.
84_Chevy_K10 said:Wheel travel from your leaf springs was apparently optional.
85m1009 said:Here is our newest innovation in traction control, dubbed the "Wrap Zapper". More info is available on our website http://www.mo-offroad.com
crazy_swede_73 said:"Wheel travel from your leaf springs was apparently optional.
__________________
Tim "
No,,,it works just like a two piece driveshaft, allowing the bar to move with the suspension.
BlueBlazer62 said:Nice design, I always liked doing it that way over the shackle, much simpler and cheaper and just as effective, good job!
85m1009 said:The price for the traction bar with the center mount is $425.00. The price with the truss and traction system is $625.00. There should be no welding involved, unless you have to modify the front crossmember. You mount the front crossmember by drilling two 3/8" holes in each frame rail, the center diff mount uses the top 3 or 4 bolts in the cover and a pinion bracket either a cnc cut ubolt, or a plate that attaches to the pinion support like with the 14 bolt ff. Once you have both mounted you determine the length of the upper tube which is already welded at the front end, cut it off and drill a 1/2 inch hole to mount it on the diff bracket. Once you have the top bar mounted you set your pinion angle measure your hole centers for the bottom bar, cut it to length and drill another 1/2" hole and bolt it in. Should your pinion angle change in the future you either shorten or get a longer bottom bar without having to modify the rest of the bar. If you do not like the way your truck corners on the street, with a locker, you can pull out the bottom bar and keep it with you until you are in need of traction control. If you change rear axles you can buy the different center mount without buying everything all over again. The slip shaft rides in a 4 inch long bronze oil impregnated bushing and does not require lubrication. The shaft has 6 inches of slip which is way more than most suspensions require.
55Willy said:why would you need that much slip? part of my plan was to limit the axel travel if the springs descide to bend, keeping the axel out of the transfer case.
