trade th400/203 adapter for th400/205 adapter
chevkong
Registered Member
nw ohio
hi i was wondering if all non divorced 205 chevy transfers are the same i have a th400 tranny bolted to a 203 transfer i understand some may want this to build a doubler? well anyways i have found a good 205 with the sm465 stick shift on it i want to put my 4oo on it but dont know if all transfers are the same if i can trade my adapter for the th400/205 adapter i will do it any interest please pm me also do i need a inner splined sleeve to connect the shaft inside the adapter i will also need this thanks kevin
400/203 is one adaptor and output shaft.
400/205 early fig 8 bolt pattern to tcase is most comon and uses 1 output .
400/205 late is round tcase pattern and diffrent output yet.
th350/203 and 205 same out put shaft in tranny. but 2 diffrent tcase mounts.
sm465 early 85-90% of them out there are fig 8 style tcase pattern mounting and use 10 spline 4 speed only shaft.
you can swap inputs on tcase but 400/205 requires bigger bearing in case. 2 ways. bore out the tcase hole bigger. or search on here for the swap bearing part# that lets you do it with out borring the tcase hole out.
