fireplug
Does anyone bother carrying spare wheel bearings/seals on the trail with them? I have amassed a bunch of spare stuff from my front end work that I can return or stash. I'm thinking it's probably not worth it but...
bent72 said:What I have seen done is mounting a spindle complete w/ the bearings, rotor and hub, backing plae and lockout all as one unit. Just build a plate to bolt it to and throw your spare tire on it as your tire mount.
Hossbaby50 said:I carry one set of inner & outer wheel bearings and races for my 10b front. This way if I have a bearing seize I can replace it and get back to the trailer.
Harley
I also carry a spare spindle incase I frag a stubshaft and crack a spindle or the bearings seize and screw up the spindle.
but if something breaks I probably have the part or a way to fix it as you already know. Now that I have a towrig & trailer I will be leaving some of the bigger stuff like steering box, knuckles, etc on the trailer in a toolbox.
Crap bro...a complete spare NP208?
Avery4jc said:You could probably wheel a heck of a lot harder without an extra 1000lbs of spare parts in the backCrap bro...a complete spare NP208?
I would only carry that much stuff if I was going on a month long trip or moving...Hossbaby50 said:You'll have alot of crap to pick up if you want to carry all the stuff I do.I also carry a spare spindle incase I frag a stubshaft and crack a spindle or the bearings seize and screw up the spindle.
Here is the short list of just parts I carry:
Inner & outer wheel bearings & races
spindle
locking hub
TRE (all mine are the same)
axleshafts w/joints
driveshafts w/joints
steering box
stock pitman arm & draglink
front brakeline
10b pinion yoke
stock knuckles
ujoints (1350, S44, 1310)
alternator
starter solinoid
belts
cap, rotor, wires
main leaves F&R
That doesn't include all the other stuff like TPI electrical parts, elec parts, bolts & hardware, ignition parts, tools, survival gear, welding supplies, etc. Trips of more then 1 day I usually have a 2nd spare tire & also a spare transfer case (208's are cheap).
I carry way to much crapbut if something breaks I probably have the part or a way to fix it as you already know. Now that I have a towrig & trailer I will be leaving some of the bigger stuff like steering box, knuckles, etc on the trailer in a toolbox.
Harley
