Trailer wiring
90K5
Lubbock, TX
I got a trailer at a junkyard for $55 today and it was in pretty goos shape except the wiring was trashed. i picked up new light, and a wiring harness today and put them on, and it works, but when i have one blinker on in my truck, both of the lights flash on the trailer. Does anyone know what causes this and what I have to do to fix it?
90K5
See my truck at <A target="_blank" HREF=http://albums.photopoint.com/j/Albumindex?u=1329584&a=9886502>http://albums.photopoint.com/j/Albumindex?u=1329584&a=9886502</A>
Sounds to me like one of the wires is hooked up the wrong way. Bad thing about trailers, the wiring, however simple, always seems to be a problem. If they are both flashing, the ground is ok...but it sounds like maybe one of the wires is connected to the truck wrong, like both of the trailer wires are hooked to one side of the signal on the truck side. Or if they do it no matter which directional is on, then perhaps you have both wires hooked up to both turn signals...did you buy one of those plug in adapters that lets you install the flat 4 connector without cutting the truck wiring??
Dorian
My K5 and Chev/Olds links: <A target="_blank" HREF=http://yeagerd.home.mindspring.com/index2.html>http://yeagerd.home.mindspring.com/index2.html</A>
I fixed it, but I don't know how. I turned on the flashers and then the blinker, and it worked.
90K5
You know it will come back next time you go to use the trailer don't you? : ) My trucks left front turn signals recently decided to once in awhile ignore my requests to flash. Flip the switch right, then left and they usually work again. Weird that onlt the rear works 100% of the time, and not the fronts, since they are on the same circuit. your trailer sounds the same way. nothing really could have changed you'd think, but there you are, they work. No chance of a short or anything where the wiring was added?
Dorian
I looked at the wiring really good and it seems OK. I didn't put rubber things in the holes it goes through, but I don't think it matters, i did a good job putting it on...
90K5
I've had that problem caused by a bad ground between the trailer and the tow vehicle. You'd think that a good ground is made between the ball and the trailer but it doesn't always work that way. You end up with a problem that comes and goes.
Smitty
It's always a good idea to run a good ground wire from truck to trailer and not just depend on the ball making a good ground. Sometimes the lights will try to gound thru themselves....
Michael
If you have the common 4 wire hook-up the white wire is usually the ground.
Smitty
hey man I do that for a living and if you have any other probs, I can come up there and rig ya up. later on.
Bryan
Durant, Ok
I have the 4 connector thing, with the white ground. The old harness wasn't even grounded, the ground wire wasn't even stripped. If I have any other problems I can't figure out, I'll ask you laketex, thanks
90K5
