Sounds like you overheated it. Fluid has to go somewhere.
Check the fluid to see if it smells burnt and reguardless, I'd change out
the fluid and filter before you drive it or you WILL smoke it.
Had it been sitting long? If the pump is worn or if it is overfilled and sits a while fluid will sometimes puke out the dipstick when you start it up. The fluid in the converter leaks back past the pump and over fills the pan.
It was still cold. I have driven it about 50 miles since without any further problems, shifts fine. It seems so far like an isolated incident (are there really any?)
