mo
I am having a hard time understanding what is going on with my tranny cooler lines. I am running two coolers now with a fan and briefly with a remote filter. Yet my tranny temp will still climb right up to 250 if i let it, in my driveway doing nothing.
here's a crappy diagram of my setup...
I was thinking maybe the filter was being too restrictive, and not allowing enough ciculation so I unhooked the lines at joint #2 and tested to see if much fluid would come out of the cooler filter setup. I was surprised when a hole bunch of fluid came out the return line off the tranny (side B) and very little came out side A.
So i thought maybe i had the lines reversed and that line wasn't the return line, so i swapped the lines. same thing happened, lotsa fluid out the tranny side, not much through the cooler setup.
So does fluid come out the return line if there is a restriction in the out line (such as an inline filter)?
So i took the filter out of the loop, but still did not return fluid into the tranny (Joint 2 unhooked). this time more fluid ran through the coolers and out side A, but a good amount still came out of the return line on the tranny (side B), which doesn't make any sense to me.
Maybe if there is no pressure pushing in on the return line, then fluid will come out of it also?
thanks!
thanks!
