Just an added tid bit
Wile your flushing (Like JR mentioned
Once your done, change the filter in the pan one last time then add a spin on oil filter in the return line from the cooler.
This type of filter (regular engine oil remote is fine) will catch a lot of crap that comes from the converter and back to the tranny.
Change that new filter every engine oil change and then add necessary fluid to top off.
Auto trannies make loads of crud. You can see this in the pan. Its a thin gray soot like material.
Mostly its fine metal particles and materials from the friction parts (clutches, bands etc)
The filter in the pan is little more than a CLOD sifter.
The trannies dont like this junk, especially the valve body.
The 700R4 is really succeptable to issues when the fluid becomes contaminated with crap.
The torque converter is a major source or crap too.
Small amounts of flexing and wear in the turbine and pump blades makes lots of this sooty fine metal junk.
The add on filter will clean that stuff right up.
If you dont already have an oil to air cooler, get one.
I prefer to block off the radiator cooler and use the air to oil cooler totally.
The only issue would be if you operate in severe cold climates in the winter.
Fluid that stays too cold can cause some issues too, but not as much as too much heat..
Have fun
Snowy
