On a 2wd TH400, should there be any play in the output yoke? (fixed, not slip)
I'm trying to find a strange noise in the driveline. After taking the prop shaft off I noticed I could move the yoke up and down a bit. More than I would've thought was acceptable. Does the yoke run in a bearing or just slide over the output shaft and bolt up?
