I replaced the gaskets on top of the motor and now the transmission wont shift out of first.I think it may be a vacuum problem.Is there a place i can get a diagram for the vacuum system?Is there something else i may have left off?
did you hook it up to a direct port or a tempature switched port? as long as you are getting vacuum to your modulator you should have no problem with shifting
