4x4_76
What is that manual tranny in front of 203? Is it SM465?
Wtf???
My bet is it's an NP435. The front axle, auto trans and trans crossmember appear to be Dodge so I'm betting the manual trans will follow suite.
Yeah, that's Ramcharger/Trailduster frame. Is that NP453 worth buying?
The NP435 is very similar to the SM465. The strength and gear ratios are very similar between the two.
It was used by Dodge and Ford quite a bit through the 70's and 80's (and by GM in a few rare cases).
Is it worth buying? That all depends. It is a good transmission, but it depends on what you need it for and how much it costs.
