sunnyc123abc
So on my 700r4 it appears to leak around the pan on the pass. side. I have replaced the gasket billion times with cork, rubber, paper, i've tried putting little grease on the gasket,i have changed the pan, i have tried tighten bolts hand tight, i have tightened them pretty tight, i have changed the pump seal, pump bushing, torque converter, I have tried just about everything. What could be causeing the leak? Pls help.
