Tranny mount
James
Castaic, Ca
desperately need the bolt sleeve for the transmission adapter plate that mounts to the crossmember. The sleeve is approx 1/2in by 2in goes between upper and lower rubber mounts that 1/2in by 3 1/2in bolt goes thru. th350 tranny and np203t-case. Anyone have or know where to find this damn thing. I would appreciate it. Believe it or not cannot locate this piece. Have one of two needed. Holding up installing tranny and t-case. A 2.00 part. Its killing me.
Peace
James
Salvage yard or go to a plumbing supply store with the other one and get something close enough to get you going.
You really decide you need them, I've got one in the back of the pickup right now. It's outta an '80 blazer parts truck and fell off on the trailer. The other one may still be under it, I don't know. You want it, I'll slap it in an envelope and send it to ya. Let me know.
Bryan
Durant, Ok
'79 Blaze- 350/350/203, 14B w/detroit, D44, 4.11s, 4" susp, 36" TSL
Going to the local junkyard at luch today. I appreciate it. I will let you know tomorrow am asap. Thanks lake
James
let me know how you make out ...
under her...
I think i may have a bad mount as well...
when i cut the wheel or punch it on a hill from a stop
i get a rubbing noise / that sounds like the fan hitting
its shroud...
motor mounts are good...
Hey B,
Gettin a little personal don't ya think. But if ya must know. I make out alot better when I'm on top of her :)lol
Peace
