bot0611
Wich one would be good.
Stock depth or a deeper pan??
Steel or aluminum?
Steel or aluminum?
yeah, what are the advantages to deep and normal pans, gotta worry about bottoming out with a deep pan or ground clearence? i may eventually wanna get a pan for my 400 with a drain plug so..
As for pan depth, depends on what trans you're running. If it's a 350 or 400 either pan is good but a 700R4 i would go with the deep pan since heat kills these trans and the more fluid it can hold the cooler it will run.
