Tranny shifting hard from N to D....
bot0611
Chula Vista, Ca
So when shiftin to D you can feel a big "smack" under the truck and and "clanck" noise it use to do it in R a long time ago now its doing it to D.....i jacked the rear wheels the other day and if i turn the d-shaft theres some play turning the shaft on the tranny/t-case side i mean you can turn it a bit before it stops beign in P so im guessing the tranny....what do you guys say.
Normally this is caused by loose splines at the rear of the tcase to driveshaft connection. Famous GM problem. There is a special denser grease you can pack the splines with, but other than that, something you learn to live with.
Check all your ujoints though, this will make it worse.
Dang...im still going to rebuild the t-case maybe ill find some bad stuff in there.
Thanks man.
If the trans is a 350 or 700R4 it could have worn case lugs or sun shell which can cause some clunks and clangs when put into gear. On a 4x4, a little slack in every component can lead to a lot of slack at the end...
I'll second the u-joints. Easy and cheap to replace and a simple way to diagnose other issues.
The U-joints are practically new, spicer's did it even before changing them and still has it.
Some slop is going to be normal wear.
One thing that often gets overlooked is RPM.
It does not take much over the normal idle RPM to make a lot of noise when you put it in gear.
If your base idle is off, then it needs to be adjusted.
Otherwise, every joint, gear, and spline will have some slop. It all adds up.
But, one may have more than normal.
If the rear output splines are worn, and you have to go in there anyway, ask around about a slip joint eliminator kit. Don't know if its available for yours or not.
The main advantage I see, is that it moves the spline out of the transfer case into the drive shaft where its easier and cheaper to fix when it wears out.
If the RPM is good, then try this:
Chock your wheels good. Put the truck in Neutral, slide under and grab your drive shaft.
Twist it rapidly from one stop to the other listening for the noise and looking for excessive movement in U-joints.
Once you hear the noise, if you cannot isolate it, try twisting the shaft more gently to see if you can run it down.
Also, push it up and down looking for slack.
The problem could be in the rear end. The rear yoke should not have any up and down movement.
If you have a locker, lots of them have more twist slack than a regular one.
Make sure you inspect all mounting bolts and nuts really well. Spring bolts on the rear end, transmission mounts, transfer case to transmission bolts, anything in the drive train that holds any part to the truck or to another part is suspect.
If all else fails, drive it until it breaks and then let us know what it was.........
Well, i did see once a lil bit of play (ud and down) on the t-case side just a bit in fact i have a small leak in that seal just drops, a SYE would be nice but that shiet is espensive, im saving right now for a detroit cause im not liking the lincoln anymore although i love the squeek od the tires when i drive to the gas pump..:D
