scottystills
Had some oil leaking from the tcase adapter, front and rear outputs, and the bottom of the rear inspection. Picked up the rear output shaft seal for the transmission, and the front and rear outputs on the tcase, figured I'd pull the tcase out and do some seal maintenance.
Hopped under and went to drain the tranny first, pulled the top plug then bottom and only a couple litres came out. Chalked it up to the thing leaking and moved onto the tcase. When I pulled the fill plug on the tcase to my surprise gear oil spewed out for a couple minutes. Not a slow drip, solid stream fill hole diameter. No visible water in it, looked like clean-ish gear oil. Finished draining it and nothing looks out of order but a little confused how the tcase could have filled so much? Obviously I couldn't have done that jamming oil bottles in...
Is there any way the tcase could have pushed gear oil into the tcase somehow? Going to take a closer look through the adapter when I get it dropped tomorrow.
Per sig, SM465 and NP205.
Thanks!
Thanks!
