Yeah I juss wana know if you can and how. I need to convert my transmission into a stcik . i have a 700r4 it keeps blowing i went through 3 i juss wana know if i can do it and how to move the 4 wd shifter thanks
Yes it can be done. If you swap from a 700R4/208 (or 241) to a 465/208 (or 241) the shifter will not have to be moved. You will only have to swap all the clutch stuff, add a third pedal for the clutch, add the shifter in the tunnel, swap transfer cases (or swap input gears), and you will need to swap the tranny and tcase adapter.
