Maybe this will help all searchers!!! For all Trans...
Cooler Fittings
General Motors Ford Chrysler
GM Transmission Cooler Fittings
Powerglide - OEM
Fitting Location Thread Size Flow Direction
Upper ⅛" Pipe Return/in
Lower ⅛" Pipe Cooler feed/out
Powerglide - Dedenbear
Upper ¼" Pipe Return/in
Lower ¼" Pipe Cooler feed/out
TH200C Metric, 2004R
Upper ¼" Pipe Cooler feed/out
Lower ¼" Pipe Return/in
TH350, TH250
TH400
700R4/4L60/4L60E/4L65E
4L80E (1991-1996)
4L80E/4L85E (1997 & later)
Rear ¼" Pipe Return/in
Front ¼" Pipe Cooler feed/out
Ford Transmission Cooler Fittings
C3, C4, C5, C6
Fitting Location Thread Size Thread Size Flow Direction
AOD
AODE/4R70W
E4OD/4R100
Chrysler Transmission Cooler Fittings
All Torqueflite
Front ⅛" Pipe Cooler feed/out
Rear ⅛" Pipe Return/in
