Trans fluid leaking into Transfer Case
PaulZ
700R4 fluid went low, not leaking (that badly). Just drained two quarts out of the 241 fill hole. Just one seal? Hard to replace? Like to have the stuff before I pull it apart, daily driver. Thanks.
I may be wrong, but only seal is the front transfer case seal. Some oil get into the adapter from 700r4, but I think there is a drain hole back to transmission.
input seal on t-case . gasket or RIGHT STUFF gasket sealer maker for adapter to t-case face . square cut special o-ring for adapter to trans body only .
fluid will drain from trans and adapter a little bit . if you wana cheet a little make the rear higher than the front to level out the trans .
Thanks guys! So my brain somewhat cleared this morning and I remembered, earlier this week I parked overnight and then some at my cabin with it pointed uphill, pretty good slope and a load of bricks in back. Since I haven't noticed this before, I'm thinking that may have caused it, along with perhaps a worn seal. So I'm going to order the stuff to fix it, keep a close eye on the trans level and not be in a rush to fix it.
