trans mount for 5.3 swap?
75K5
Michigan
driving around my 75, has a 5.3L, 4L70E, and nP241 swapped in. I think the pinion angle is too steep, getting some bad vibrations around 70mph.
I am curious, what did you use to mount the 4L60E to the cross member? I used the transmission mount that came off the 4L60E from a 2009 tahoe, but it's about 2" tall. Wha did everyone else use? something shorter would reduce drive shaft angle.
thanks,
Brian
following up on my own thread. my problem was that I was using the wrong trans crossmember. When I Swapped to the NP241 I should have also taken the crossmember that came from the NP241 donor truck. I was using my NP203 crossmember and that was causing all kinds of problems.
Brian
