ktedesco
My transmission/transfer case bounces alot more than I think it should. It also makes a clunk sound during a hard shift. I ordered a poly mount for it through ORD and it should be arriving tommorow. Hopefully this cures the problem. I guess the next step is motor mounts.
Question is, I can't find any info on replacing the mount. Is it as simple as it looks? Put a jack under the transfer case, raise slightly and support, remove old mount and replace with new then remove jack. I just don't want to run into anything unexpected (yea, right /forums/images/graemlins/whistling.gif). Thanks all!
