would a 700r4 trans from a 1986 k5 work in a 1990 k5. Is this a clean one for one swap?
thanks in advance
thanks in advance
The 1990 model uses different electronics internally than the 1986 Carb model. You can, however, swap electronics between the two. The 1986 lacks the better input and low sprag of the later models as well as the auxilliary valve body system and other durability upgrades.
The only electronics going to the trans should be that plug which controls torque convertor lockup. You don't REALLY need to hook it up but it's better if you do. It should work just fine. You might want to verify that the TV cable is the same length for the two trucks since one is carb'd and one TBI. They should be the same with the same throw and geometry but I truly don't have that answer.
I dont remeber any electronic or vaccum hook up switches on my 86. I am certain its not the original trans to begin with. How can I identify the trans that is in it and what it really is from or for? I am 100% sure it is a 700R4. Also now that I think about it I beleive there is a electric square connector on the same side as the govener but I dont beleive anythign is hooked up to it....
According to info I have found it is a 1987 4x4 5.0V8 V1 series trans
The 7TXM is a 5.7 model but both are virtually identical internally so just choose the cleaner of the two. Both are the preferable 87-92 variety
