I have a 1974 K10 came with turbo 350 and NP 203 putting in 700R4 with the np205 twin stick do I need to change the tranny mount if so can I buy one somewhere pre-made thank you
Are you using an aftermarket adapter or the original adapter from th350/205?
If it's a stock adapter then you just need to move you mount a couple of inches back.
Unless by tranny mount you mean the adapter between the 2
