Jacks'72K5
Registered Member
According to the spec sheet, my 72 K5 is running the TH350, 2.52:1, with the NP 205, 1.96:1. I have a 700R4, 3.06:1 attached to a NP 208, 2.61:1. Am I going to run into any major problems swapping these two sets? If I understand the ratios correctly, this will drop my final drive ratio by 1.19:1. Am I correCT?
The 700R4 is from a n 84 6.2L, does that have a different bell housing pattern than the 350?
