rpinkstn
Registered Member
'86 K5 with rebuilt 700r4
the P.O. claimed he rebuilt the transmission (700r4) himself - he also admitted it was his first transmission rebuild
. transmission wasn't shifting right on test drive, but it was shifting. I noticed the TV cable wasnt adjusted correctly so I wasn't too worried about the high rpm 1-2 shift - bought the Blazer.
Haven't driven it much but started working on it recently. seemed like the 1-2 shift point kept getting higher until now, no 1-2 shift at all, stays in 1st. pulls hard in first, no slipping. reverse works fine too. I pulled the governor and noticed the piston *does* stick down (toward the gear) - could this be what is preventing the transmission from shifting??
Thanks for reading!
. transmission wasn't shifting right on test drive, but it was shifting. I noticed the TV cable wasnt adjusted correctly so I wasn't too worried about the high rpm 1-2 shift - bought the Blazer. Haven't driven it much but started working on it recently. seemed like the 1-2 shift point kept getting higher until now, no 1-2 shift at all, stays in 1st. pulls hard in first, no slipping. reverse works fine too. I pulled the governor and noticed the piston *does* stick down (toward the gear) - could this be what is preventing the transmission from shifting??
Thanks for reading!
