transfer case adaptation questions
firemedicsafd
Professional Murphy magnet
St Augustine, Florida
I have an 82' k5 blazer 700r4 and stock transfer case in my project. I bought 1 ton axles and i want to replace the transfer case to the all gear model. Which T case is the one i want to look for? What adapters do i need? can it be done without divorcing? Thank you!
The np205 is the case you want. Since it never camer behind a 700r4 you'll need one from a th350 with the adapter. You'll also need a spacer (1", iirc) for the trans side of the adapter.
