GonicGM
SM465 short transfer case adapter to NP208 $100 required to swap SM465 onto TH400 NP208 for conversion.(requires 1985 and newer crossmember).
SM465 short transfer case adapter to NP205 $150 required to swap 32 spline SM465 onto TH400 NP205 round pattern, for conversion.
TH400 to NP205 short adapter. $225 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP205 from 1985-1991.
TH400 to NP205 tall adapter. $200 Excellent condition, fits 77-84.
TH400 to NP208 tall adapter. $175 Excellent condition, great for SM465 4 speed to TH400 swap, required to install TH400 onto NP208 from 1981-1991 (requires 1984 and older crossmember).
1985-1991 Double hump crossmember. This crossmember is required on 85-91 solid axle trucks and to retrofit short style adapter installs to 84 and older. $150
1985-1991 Single hump crossmember. This crossmember is required on 85-91 solid axle trucks and to retrofit short style adapter installs to 84 and older. $65
Factory skid plate for 1985-1991 single hump crossmember. $45
1977-1984 K30/K3500 flat crossmember. It is also correct for all years military CUCV D30 M1008 M1010 M1028 M1031. This crossmember is required to retrofit tall style adapter installs to 85-91 and newer one ton 4x4. $65
Shipping is additional on all items unless local pickup.
