I have a 91 K5 with a stock drive line. It has a 7 inch lift with a 1 inch transfer case drop. Since dropping the transfer case it leaks a ton of trany fluid. Its not leaking from the transfer case so I'm guessing it must be a seal where the trany connects to the transfer case. If there is a seal can it be changed without dropping the trany?
