1993 K1500 4wd truck with 241 C transfer case. I just overhauled the transfer case, refilled with tranny fluid to bottom of fill port. In a couple of days I noticed a small puddle of red fluid (I did find where the case had a slight leak), but the problem was when I pulled the fill plug to check the level, fluid gushed out. The case was way over full. Does th transfer case fill from the transmission? If so, is this right or is there a problem?
