crazyorigin
Registered Member
I just picked up a blazer chassis w/ a 12bolt rear, and dana 44 front axle. I am not sure of what the transfer case in it is. I'm pretty sure it is a 74 blazer chassis, but there is no garauntee the t-case is original, it used to have a 66 chevelle frame and body on the blazer chassis. It is a divorced transfer case, and i was thinking it is an NP205, but it looks odd, it doesnt have the large cast aluminum covers for the gears on the one side. Here a couple pics, one of each side.
Thanks for any help, these axles will be going under my 87 Shortbox this winter, along with the Pro Flo MPFI 400 small block i had put together for it, i am excited! Hopefully this t-case is worth using. The lever off the front only seems to have 2 positions, engaged and disengaged, but i may be missing something. If i can get it ID'd we'll go from there.
