B.N.Z.MTNS
Elevation 8,500’
Here's my dilemma. My factory NP 208, T-case is leaking out of the tailshaft at the slip yoke seal. I have replaced the seal twice and it isn't helping. I'm pretty sure the bushing is bad as I do get some vibes on deceleration and sometimes while cruising at highway speeds.
I am either planning on getting this kit from Tom woods along with a new driveshaft
208 Transfer Case GM Design - 32 Spline Output
Uses a modified stock shaft conversion kit provide with: Precision modified main shaft and original equipment speedometer housing which has been re-machined to accept the stock rear out-put seal.
...... or ......
I have a lead on a used NP 241 that I could put a JBC SYE kit on and use a new driveshaft.
Everything I have read says that they are both just as strong as the other and the only real advantage to the 241 is the lower gear ratio. I need to get rid of the slip yoke either way and I already have the 208. If I do the 241 option I will probably be into it for another $200 - $300 over what my 208 conversion would cost.
Will I really notice the difference between 2.61:1 and 2.72:2 ratios? Will 1/10th rotation in my low range ratio be a noticeable difference on the trail? Are there any other advantages on the 241 that would warrant spending another $300 bucks to get my rig trail worthy?
I am trying to get ready for my first Blazer Bash this year and need to get my rig whipped into shape.
Other info on my rig if it helps for input: Stock TBI 350, 700R4, D60 & 14BFF, 4.56 diffs, 38" tires.
...... or ......
Oh, and I still have my 208 wrapped up in a trash bag in my garage. It's my spare for trips like Moab.
. And if you looked at the 32 spline next to the 27 spline, you would realize how much more special it really is
