transfer case problem
rbk587
Registered Member
brandon ms
the last couple of times i have put my blazer in four wheel drive it jumps out of gear.it kinda clunks then you hear a pretty distinct whine.jus started doing this the last few times reckon its serious or adjustment or fluid change in order?thanks for some good news
you might want to check to see if it is engaging all the way into 4wd. is there a body lift on it? are your t-case mounts and engine mounts in good shape?
no lift kit completely stock.my engine mounts are fine far i can tell,i put it in neutrel and it seems to engage then pop out.i jus came out of the woods used it and no problem
what about your t-case mounts? body mounts? if they are wore out it would let the body move and knock the lever out.
