Never Satisfied
I'm no stranger to turning a wrench, so how hard is it to rebuild a 241 case? Are there any places semi local to me that offer this service?
So, my truck has 339k miles on it and I have no idea if the T-case has been rebuilt/touched or not.
I'm thinking a new chain as well as a rebuild kit.....but would I also need to get a new shaft too? Can the teeth wear down on both ends as time goes by?
Take your time, have a nice clean t-case to start with, a clean workbench to work on, and take good pics as you tear it down. There really isn't much to the NP241. I bought my rebuild kit from JB Conversions, along with their SYE kit. The rebuild kit is very complete. Oh, and I replaced the chain too; the old one had quite a bit of slack in it. With 180k on yours, it could probably use a complete rebuild.
. I also had a HF press to remove bearings and stuff. It was a really easy job. Your pump is probably fine....you would know if your pump was out (in a couple thousands miles probably) and the shaft is probably fine too, but you can look at it as you split the case. But once you do it, you realize how simple of a tcase it really is.I know this is an old thread but where is a good place to get parts? I'm looking for a chain for my 241. I'd rather not buy one off ebay.
