JeffsJeep04
My 208 seems like it's on the way out. I'm guessing worn shift fork pads are the root of the issue based on past experience, but regardless, it has developed a whine in 4x4. Happens whether the hubs are locked in or not. I started searching around for a replacement and managed to score an NP241 from an 89 suburban
Plan is to roll with the 208 as long as possible because...well, it's cold out!
Anyway, I got the case with the adaptor and I'm trying to figure out what the best way to tackle this is going to be. I've always been a manual transmission guy, so this auto stuff is still new. I'd like to pull the case off in a way that will avoid loosing any fluid from the transmission if possible, but I'm open to ideas from those who have done this before. Am I better off unbolting the adaptor from the t-case and keeping the current adaptor in the blazer, or should I save myself two bolts and pull the 208 with the adaptor attached?
Plan is to roll with the 208 as long as possible because...well, it's cold out!Anyway, I got the case with the adaptor and I'm trying to figure out what the best way to tackle this is going to be. I've always been a manual transmission guy, so this auto stuff is still new. I'd like to pull the case off in a way that will avoid loosing any fluid from the transmission if possible, but I'm open to ideas from those who have done this before. Am I better off unbolting the adaptor from the t-case and keeping the current adaptor in the blazer, or should I save myself two bolts and pull the 208 with the adaptor attached?
Seriously, it was way easier than a creeper.
