blazinbg
how interchangeable is a np241 to np208 in 1983 k5 700r4 trans.?
Could you tell me more about this swap, I realy want to do this.It's a direct swap BUT you have to find a one year only (1989) NP241 as that's the only year for a mechanical speedo.
You'll only be able to get a mechanical speedometer drive NP241 with the same spline count as your 27 spline NP208 from a 89 Suburban, Crewcab or K5 with a 700r4 as well. That said, you can also get them from the 3/4 tons and 1 tons with manual transmissions and 4l80es and trade someone here for their 27 spline input shaft.
The NP241 has a slightly larger chain than the 208 does, and IMO, is more than strong enough for anything you can throw at it. Same goes for the 208, only real weakness is that aluminum housing...
Also keep in mind that it isn't impossible to purchase the parts needed to switch an electric speedometer NP241 over to mechanical, nor is it impossible to install an electric speedometer in your K5.
I am personally running a 32 spline NP241 behind an NV3500 with an electric speedometer from a 91 all installed and playing nice together in my 1985[/quote
Thank you for your reply, I want to switch out my 208 for a 241 because I want to install a slip yoke eliminator kit.
Now that I know its possible to switch from an electrical speedo to mechanical, What other vehicles can I get a 241 from besides a 89 K-5 to go into my 88 Blazer with mechanical speedo?
Thank you for your help,
Ed
1989 was the first year for the NP241 and the only year for mechanical speedo however you can use an NP241 from any blazer/burb/crewcab up until 1991 but you will either have to convert it to a mechanical speedo or deal without a working speedo and VSS. 1992 and later NP241's will be a driver drop case and WILL NOT work unless you swap in a HP D60 from a Ford.
what would it take to switch from an electric to mechanical speedo?
From what i've heard you have to swap the output shaft and everything that goes along with it including the tail housing.
I have a JB SYE on my t-case and it DOES NOT come with any portion of speedo stuff at all.
Ok, good to know. I guess the hole in the JB bearing housing is just for the speedo cable part.
There is some one here in hawaii with a 241 from a 90 K-5 Blazer, I was thinking of getting that and finding the parts for the mechanical speedo conversion. This might be easier then to look for a 89 only vehicle.
you continue to educate me, you've been a big help.
Thanks,
Ed
How does the NP 241 compare in strength to the NP 208?
As mentioned, you can go to an aftermarket speedometer to work with the electric VSS (Vehicle Speed Sensor). Basically every vehicle made in the last 20 years uses them and they are VERY easy/cheap to find aftermarket.
The 241 is basically the NP208 version 2.0. All of the concepts are the same, aluminum case, chain drive, planetary gear set, 2WD/4WD with a low range etc.
The 241 got a stronger gear set (varied based on application but almost always better than the 208 stuff), better oiling, things like that. Think of it as the improved version of the 208.
JagsthatRun.com carries such a device, but I would not reccomend one... That little electric motor cannot be trusted to accurately translate the speed forever...
You'd be far better off swapping to an electronic speedometer to match the VSS no matter which way you look at it. I don't know for sure about the 241, but I know it is getting tough to find different combination of the speedometer drive gears for the 208 these days, so getting your speedometer accurate if you change tire sizes or gears could be a challenge. While I know that it doesn't get cold where you live, speedometer cables eventually wear and start to bind causing the needle to jump around at slower speeds (usually made worse by cold temperatures).
The 90 speedometer is an easy install. Two wires run down to the VSS on the transfer case, one wire goes to ground, one wire goes to 12V ignition, and one wire goes to the electronic speedometer. The speedometer is grounded and powered by the instrument cluster. While the cluster does require you to re-pin your wiring at the cluster, it is easily done, and well documented online.
By modifying the DRAC you install to control the speedometer with a simple DIP switch, you can calibrate it for virtually any gearing / tire size combination possible with just a basic calculation and setting of said DIP switches to match a pre-determined chart.
