So guys my np203 chain is worn out and skipping teeth and I've found another 203 on Craigslist. My question is what's the best way to pull the t case to swap them. Mechanical ability isn't an issue as I've already pulled the tranny/tcase combo once before as a unit and then reinstalled it. Can you pull the t case alone fairly easily by just unbolting it from the crossmember and dropping it or will it be easier to pull the whole tranny and t case from the crossmember? I'm thinking just drop the t case. Let me know yalls thoughts. Thanks
