transfer case?
If its the 203, get underneigth and you can adjust the linkage by lining up the holes in the linkage arms.
is it a common problem that the transfer case on a 77 k5 wont go in to lock?
Very common, my 203 had the same problem for a while. Clean it up and adjust it(right way), or just kick the hell out of it to get into lock(wrong way).
There is a hole on the side of the shift linkage that you can put a drill bit or a small screwdriver into and line up the shift arms til the screwdriver can go all the way through it
