Transfer case???
89Jimmyjon
Registered Member
Largo , Florida
Heres the deal. I have a 89 Jimmy. She is got about 2-3 inch lift on here from the military. I have 33s on here. But I want a diesel. There is a K-5 blazer for sale 1000$ Diesel. Lifted 9' inchs and on 35 boggers. Only problem. It needs a transfer case and a driveshaft front and rear. Will my driveshafts work or at least my transfer case work on the diesel??
Not nearly enough info.You should atleast know your trans and tcase to start with and then find out what trans is in the other truck.You didnt even say what year the other truck is.I think your trans will bolt to a diesel but not sure.I yanked a diesel and installed a sb350 years ago for a customer but dont remember if the trans needed to be changed.If thats the case your drive shafts should work if the wheel bases are the same.
Is something wrong with your trans?If your transfercase dont work with the t350 use your whole setup and bolt it right up to the diesel.I guess the drive shaft legnth would be something you find out on your own.
