crossy
88-98 14 bolt corporate rear diff, 3.42 posi. ,102K, $400
1992 fits 83-92 , 4x4 700R4 w/ converter, 102K, worked good. $300
1984 fits 83-92 ,4x4, 700R4 no converter, 114K maybe rebuilt? came from NON-running truck so i couldn't test it. was told it was fine, take a chance ,$100.
1987 fits 83-92, 700R4, 4x4 with reman converter. 22K on rebuild, could not test, papers for rebuilld. dirty(was behind 6.2 diesel).$300
1992 ,fits?? 88-98?? 241C transfer case, driver side drop.102K,worked good,$300
1986, fits 81-87, pickups. 208C,,X-case, worked well, was behind 700R4.$125
1975, fits 73-81, 203C X-case, from behind a TH350. $50
all items are pick up here only.
LOCATED in Pennsville,NJ just 30 minutes south of Philly airport and 5 minutes from Delaware Memorial Bridge. The NJ turnpike(95) and NJ Routes 295 & 40 & 49 all end in Pennsville so I’m easy to get to.
I will trade for something SELLABLE. not something else i have to work on. Hot rod and musclecar parts are also trade-worthy.small stuff preferred.
856-678-7883 before 9 PM EST. (David) . If you DID NOT read all of this first then please DO NOT call.
