h0wl0ngcanitbe
Ok so recently i did a gear change in my K5, the thing has never run smoother. but whenever i would let off the throttle at higher speeds i would get alot of feed back from the gas pedal and would hear this awful grinding noise then it would go away after the speed leveled out or i would hit the throttle. at first i thought this was the new gears "breakin in" well a week passes and it progessively gets worse and worse and did it more and more at lower speeds not just freeway speeds. so i take it into the guys that did the gear change and they put it up on the rack throttled it, pulled the rear drive shaft and came to the conclusion that the vibrations were comin from either the transfer case or it was an internal driveline issue. the guy that helped me explained that the chain while under load in the tcase was workin, but once the throttle was off and their was no more load that the chain could be slippin.
any and all help would be awesome, this problem has never been an issue for me and it started immediately after the gear change. the hubs are fine just had those replaced. snf the sound definitely is comin from the tcase. so what am i lookin at? new tcase? rebuild? im lost. as always thanks for any and all input.
