Transmission and Transfer Case removal... need help
SlicksInRain
Chicago, IL
Going to a junkyard tomorrow. Is there a write up somewhere thst says how to remove both of these items or simple instructions?
Thanks everyone.
Remove all linkage.
Remove both drive shafts.
Unbolt bell housing from the engine. If an auto, unbolt converter.
Remove cross member.
Slide back and lower. You could separate the trans and TC then remove.
Take a friend. They are heavy.
