Transmission Fluid Out the Dipstick
Mule man
Registered Member
Arkansas
Just bought an '84 Chevrolet 4X4 with a TH350 tranny. Runs and shifts great but now it's started blowing tranny fluid out the dipstick. I blew the breather out (and blew tranny fluid everywhere) and put a dipstick with a good rubber seal on it but it's still blowing fluid out. It is about 1 qt low so no overfill problem. I did a search and it seems that it HAS to be the vent? Is there anything else? I need any advice that can be given. Thanks in advance.
I just took my air compressor, put it in the dipstick and was able to blow air out the vent. Humm now what? Thanks again for any help.
How long does it take to blow it out the only time i had the prob my in blaze the tranny was really hot
This is a longshot, but as you know, the most common cause is overfill letting the fluid get up into the gears and foam out.
You changed the dipstick, so its probably not marked wrong, but since the truck is new to you, is there any chance that something has been changed?
It could be something as drastic as different transmission from what the truck is supposed to have, to something as simple as a shortened dipstick tube.
Since a stopped up filter was mentioned, you might try changing the fluid and filter. While you do, you can note for sure which transmission it is.
Then check with the experts here and find out exactly how much fluid you should have to put in during a change.
Put in that amount and then check it with the stick.
If it shows a quart or so low, then you have found the problem.
I had a truck brand new from the factory that would blow out the first quart of engine oil after a change.
Dealer could not find anything wrong. I finally decided to just let the engine burn up under warranty.
It never used another quart after the first one.
So I just ran it a quart low.
A few years later, I found a recall notice for the trucks up to the year before mine that said the wrong dipstick had been put in some.
The recall notice said change the oil and put in the correct amount and then check it. I did, and sure enough it showed a quart low.
Never changed the stick, just ran it low.
Thinking you might try the same on your transmission.
J.
Thanks for all the replies. I've also been pointed toward "lip seals". Could them leaking cause this problem. I will pull the pan this afternoon and take a look at the filter etc. Thanks again
