transmission hessitation
bigbadchev84
Hermiston, Oregon
I got a th350/205 in my blazer, It dosent get driven a whole lot, but the last couple times I hoped in it to run some errands it takes forever(5-10 seconds) to go into gear, reverse and forward, but still shifts fine, it has a b&m shift kit in it and slams 1-2 shift and 2-3 is normal. The fluid level looks fine and nothing smells burnt, Is this something simple or should I worry?
The pump could be on it's way out. Or possiby the torque converter.
ok took it for a drive this morning and same thing, Except when i went to back up it started to shutter really bad. is this pump or torque convertor?
