I am about 6-bolts away from removing a 4L80E transmission out of my 1991 V3500 crew cab so I can rebuild it. I bought one of these transmission holding fixtures to hold my transmission while I take it apart and put it back together. My question is how to properly secure the trans with the three anchoring points on the fixture. The two screw in studs are obvious, but the third anchoring point at the base is the one I question. It appears that the anchoring point at the base of the fixture is supposed to be inserted into the cooler line port, but that has threads in it that are aluminum, and will be torn to shreds if I use that as an anchoring point. Anybody have any experience with these on how to safely mount a transmission to one of these?
