I'm getting ready to replace the transmission mount and install the cross member correctly on my '88 K5. The previous owner, during and engine swap, installed the crossmember with spacers between the cross member and the frame which I have heard is typically done to adjust for a suspension lift. My truck has no lift. When I adjust is there anything I need to check in the process - my thought is:
- I need to loosen the linkage for the gear selector and retighten when repositioned.
- I should eye ball the distributor during the adjustment to make sure it clears the firewall.
Is there anything I should be thinking about?
Thanks,
Joe
Thanks,
Joe
