Bongdozer
Registered Member
I just finished resurrecting an old 1975 k10. It’s pretty much ready to bring on the trails with a new lift and stuff. Big issue though. I can’t get it into gear i don’t know if this is from the np203 or the th350, I thought it was a low trans fluid issue, too which I added roughly 5 qts, it started coming out of the top of the fill accidentally. I noticed it seemed to shift but not actually go anywhere. It doesn’t link into gear, more of a very soft change, as if the vacuum understands it’s in gear and the engine mellows out, then goes nowhere. I tried to fill up the np203 a bit, with 30w. I got some in but only about 1/2 qt, because of the angle.
Seems like a faint grinding when the engine is revving a bit high. When it’s cold for example. I never let it keep making this noise, and only appears during rpm 1400 and higher.
This is a mystery trans. A family member “indicates” it was replaced with a good one, but never ran and that was over 20 years ago.
Any ideas on what to check? I looked at my cables they don’t seem stuck.
