Transmission selection help
K5dreamer
Alexandria, Va
Hey all, first off, where did the search bar go? i looked for it, and couldnt find it. im feelin a little retarded at this point....... i thought it used to be next to the display of your user name up in the top right corner.
Anyway, refresher, i got a 1986 M1009 diesel blazer. the TH400 has started to act up on me. nothing major, but enough that ive started to look at what my options are. Im well aware that rebuilding a TH400 is gonna be expensive, and im pricing out replacment trannies, and looking at the attractive possibility of putting an overdrive tranny in its place. So far, ive been looking at three options.
4L60
with or without computer (prefer without)
360ft/lbs torque handling
3.059 1st gear, 1.625 2nd, 1.00 3rd, .0696 4th, 2.29 R.
4L65
basically the same, just a higher 380ft/lbs torque handling.
4L80
only with computer i think :(
440ft/lbs torque handling
2.48 1st, 1.48 2nd, 1.00 3rd, .75 4th, 2.08 R.
4L85
same as above, with a 480ft/lbs torque handling.
or keep the TH400 and rebuild it.
Im just looking for opinions, or even better feedback from people who have done these swaps.
I really like the gear ratios on the smaller 4L60 and 4L65 trannies, and even with a turbo, im probly only looking at around 195hp and 360ft/lbs of torque from the old 6.2L so i shouldnt be pushing the tranny to hard. But i really like the idea of a TH400 based design thats a helluva lot stronger. I just dont know if those higher gear ratios are worth the warm fuzzy feeling.
im open to all thoughts and opinions. The truck mostly see's highway duty, with whatever off roading, mudding, and some rocks i can work into the mix. Nothing crazy.
after crunching some quick numbers, it looks like the issue over gearing is kinda moot. unless this difference in crawl ratio is bigger than it looks to me. With the NP208 transfer case's 2.6:1 ratio, and the 3.73 gears i hope to be putting in (with 12 bolt axles) this year. the crawl ratio difference between the 4L60 and 4L80 is 29.67 and 24.05 respectively. both better than the 19.86 i have now, and ill also have overdrive with lockup. Ive heard that the 4L80 is the same outside size as a TH400 and is a direct bolt in, ill just have to learn to live with the fact that ive got a computer on my rig *groan*.
any other issues ill have to worry about?
edit - thanks 38377k5, i really thought i had lost it for a second there.
