I looked around and did not find this question or any information in general.
With my 700r4 out of the Blazer, will the bell housing holes (where the tranny to engine bolts go) support the weight of the transmission if hung from a traditional engine stand??
I'd rather not have to pay the $105 for the stand that allows access to the torque converter and attaches to the SIDES of the transmission.....would rather use my existing stand.
My fear would be one or more of the aluminum holes would break off. Thought I'd ask first to see if anyone has any experience. I found one photo online of someone that did it but there was no included information. I am doing this only to support it as I clean it up and change the pan.
Also, what are the pros/cons of keeping the torque converter on the pump shaft. I understand it is full of fluid but I would like to drain it and put it aside while waiting for the reinstallation. Also, should I refill the torque converter before replacing it on the pump shaft. Thanks for any help.
/ 700r4 2wd / sm465 4x4 no t-case .
