Transmission Temp gauge and cooler questions?
1978Blazerk5
wisconsin
Well I was gonna install a transmission cooler in my 78'. Well I wanted to use steel lines to the cooler. My questions are, can i use a single flaring tool, or do i need a double flaring tool? Or would compression fitting be better? I also wanted to put a temp guage in place of the clock. Does any one know what guage will fit in place of the stock clock? and i was gonna use a "T" fitting off of the lines for the sensor should i put it before or after the coolers?
B&M has a kit, does any one know if the gauge will fit in place of the clock?
http://www.jegs.com/p/B&M/748099/10002/-1
I ran -6 an line for mine, 5/16 is the stock hardline size.
I use industrial compression fittings (swagelok, parker, etc.) and 3/8'' stainless lines on my race car. A 'T' will work fine and put it before the cooler, thats the temp which is most important.
