original balzer
The other day I had to sit on a location for a while. Two hours of NOTHING!
So I was day dreaming and thinking.
What if a guy BUILT a transmission/transfercase the way he wanted using the internals from stock trans and x-case?
Using drill casing and plate for the housing.
Caseing comes in lots of sizes and its thick and strong. One unit, yes it would be heavy but near bullet proof and the bottom would be mostly round. welding on mounts building access ports would be easy.
The hard part in my head would be conecting things and making them shorter.
This way you could use say the guts from a NV4500 the low gear set from a 203 and all of a 205 WITHOUT external adapters. Thus making it the shortest possible. Conecting the shafts inside is the part I dont really know about. Im sure with a bit of machine work it could be done.
Unfourtunatly I am NOT capable of undergoing such a project. I dont have the tools or the knowlage. I do think it can be done and would be uber trick.
BUT HEAVY! It wouldnt be any heavier than normal stuff but as 1 unit it may be akward to handle.
. The concept is neat, but someone who is a very good mechanical engineer would have to design it I think to make it work properly.
Just would take some pretty good engineering to make it happen, would be cool if it did work though.
