SkyScraper
Registered Member
Well its been a long time since I posted here, but you guys have always been very helpful in helping me figure out the problem or how to fix it.
The problem is that my Son was driving my truck this week. Been fine for years never any Transmission problems (I know better now
Today he calls me up and says it died and now I can't get it into drive or park. It just rolled down the hill and he had to apply the brake.... but Reverse works.
So when I get there that is exactly what is happening. After some work this afternoon I found that the shifter lever (not sure of the real name for the component) of the transmission will only go into reverse and if I take it to the park position it does not quite make it there. So Park doesn't work anymore and if you take it down below reverse I can fill metal on metal... best way to describe is a stripped bolt in a threaded hole... but it stops and does not go very far.
I have been trying to find some exploded views of a TH350 or TH400 (still have to figure out which on I have). Also from what I have found on that component it looks like it maybe a "Pawl" or the "Manual shaft". I also found something on TH350 Rooster. That I am not sure what it is.
Can anyone give me some insight on a repair for this or is this something I ma better off sending to a transmission shop or just sell my truck. Any websites that have an exploded transmission assembly.. my search has not been so good tonight.
I don't mind working on this myself if I can understand it and how it works.
Sorry for the long post!
Thanks,
Scott
).Today he calls me up and says it died and now I can't get it into drive or park. It just rolled down the hill and he had to apply the brake.... but Reverse works.
Thanks,
Scott
